Wont Start Help 01 F250 V10
Hi: My truck {F250 4x2 2001 V10 triton} always has run good-- but I left it sitting for 2 weeks in the hot sun. now it just wont start ? the motor turns over fine but it just wont fire up--- it sounds dry--no gas smell, no smoke, like there’s no gas getting to the motor. I have half a tank of gas, oil pressure looks ok, fuses look ok, but one fuse has a metal jacket so I don’t know, battery seems ok --what’s wrong ? could it be electrical ? A loose wire ? how can I tell, or is it a clogged fuel line? fuel filter? or dead fuel pump ? Dose the pump need to be primed somehow ?-how do I check all that out ? I don’t want to tow it to a shop if I can fix it in the drive way, any suggestions would be much appreciated thanks.
