Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Air Intake and Exhaust Guides
- How To Replace Your Air Filter
Step by step instructions for do-it-yourself repairs
97+ Cabin Air Filter - how to replace
Originally posted by PA28150
None left where ?
None left where ?
How often are you supposed to change those things, anyway?
XXL
[B]Hmmm...strange...if the kit was never popular, then why are we all talking about it?
Think about the situation logically. Your vehicle is "full" of outside air all the time, do you filter the outside air every time you breathe? Probably not. Hence why do you need to filter it inside your car? If you can find the kit and/or a way to install the filters, great, but I wouldn't lose any sleep over the matter. If you're really worried about air quality talk with the government.
Well, let's say you drive on gravel roads and you roll up the windows, but that doesn't help because the dust comes in through the vents. Wouldn't the filter be an advantage?
Yes, I believe you could replace the brackets, but they are pretty convoluted. Probably some rope caulk or something would be necessary.
PS: I think Ford recommends changing at 30,000 miles, but others recommend 15,000 (maybe to sell more). Obviously it depends on conditions; I figure I'll change it when I do the engine air filter.
Actually we all filter the air (outside or otherwise) we breath. That's one of the functions of our nostrils.
The reason we don't usually need additional filtration for the outside air we breath is that natural air currents will provide the mixing and dilution we need.
Not so inside a vehicle. You're stuck with the air drawn in. The replenishment/mixing is far below what we experience outside.
That's why a filter should be, in my opinion, a standard feature on every vehicle. I'm a bit spoiled -- I'll admit -- in that all my other vehicles have not only a particulate filter, but a charcoal one to remove odors as well. Believe me, it helps with allergies.
I don't think I'll be asking the government for any favors either (on this or anything else). Not only is such an idea completely against everything I believe in and stand for, but for "them" to help, they'd have to remove every tree, flower, weed, and blade of grass (only a partial list). As I recall, they tried doing something like that in a place called Vietnam. Pollution is an altogether different (and additional) subject, which I won't get into here.
Ford can do its part by living up to its advertising. If this feature is supposed to be an accessory, then it should be available. Period.
This is my logical thinking: It's more likely I will have a filter in my vehicle than for the government to clean up the air to an acceptable level for us allergy sufferers.
You guys seem to be suggesting to cut out a segment of the plenum box to add a filter. May I ask what opening the air flows through when on MAX AC setting? Wouldn't you want to place a filter there to filter cabin air? I think you would want to find out where air enters the system from the outside and place a filter there to filter incoming air to prevent dust and such.
My understanding was that that was where the cabin filter option was supposed to go.
XXL
In MAX A/C mode, the interior air is recirculated. There is no make-up air. That's why MAX A/C is normally used to provide an initial cool-down of the interior. It's usually easier/quicker to cool recirculated interior air than fresh air from outside. The downside is the re-used air can get stale, and you have a greater likelihood of fogging up the windows.
#28
Again, the instructions from Ford claim it filters the air in BOTH recirculate AND incoming modes. Since it is placed just before the blower fan, I do think it filters wherever the air is drawn from. I believe it is much like your house's furnace filter in this regard.
#30
