Overwhelmed on Chips
Never Adam,
I'm an honest dude. You'll all get the full honest review of the chip after i've given it a good 100 mile test run through all types of various tests and conditions. I will be very thourough and keep an open mind. Perhaps I can even find a local dyno shop to give it a real test.
Tom
Tom
Ken,
I don't remember where I've heard this, but I remember someone mentioning that on the new computers with the metal panel on the back that you have to pry off with a pair of plyers, that you have to solder a piece of wire from one diode to another so that the computer knows that you're installing a chip and so that it can access that information.
Have you ever heard this? Is this true?
Thanks again,
Tom Longo
Thanks again,
Tom Longo
on
The computers have an access hole in the back. The hole is coverered with a blastic plastic or metal piece that pops in and out, no prying required. The only exception I've seen so far are the latest Merauders which have the metal cover actually attached to the computer box with two small pieces of metal that have to be cut.
No such thing as needing a diode. A very small number of 1998 - 2000 computers are missing a power jumper and if that's the case you have to solder a jumper to two points on the board. Again, this isn't common, and it only happens with 1998-2000.
yeah Ken, that's what I can't figure out. Maybe I'm not connecting my chip correctly. My computer has the metal cover on the back that needs to be cut out. No plastic pop out cover or metal pop out cover. I had to rip mine off with a pair of cutting pliers.
How would I know If I needed the jumpers? I just want to make sure I do everything right when I put the Diablo in.
Tom
Tom
When installing the Jet chip, I took the computer off 3 times just to make sure I had it clean enough. I even went so far as to take the entire housing off from around the circuit board to scrub it extra good. I took some very fine sandpaper and sanded it down until the copper connectors were nice and shinny right up until the met with the micro wiring. I don't think I could get it any cleaner without sanding the terminals completely off. It's getting a good connection, I'm sure.
Tom
Another questions Ken,
In your opinion, which will help my truck accelerate better, going from a 3.55 gear ratio to a 4.10 or replacing the rockers with aluminum roller rockers and cams? The gear change is much cheaper.
Thanks
Tom
Tom
Thanks
Tom
#30
Ken,
bummer man. Steeda is installing a 4.10 ring and pinion for me today. This is going to toss off my odometer and make it read as if I traveled more miles than I actually did. Too bad the chip already went out. If I send you the chip back sometime in the future, would you be able to reprogram this gear ratio, or due I have to get a whole new chip, or is the 4.10 not really going to make a huge difference in my odometer reading?
Thanks
tom Longo
Thanks
tom Longo
