89 Aerostar wont start!
<--hopping mad
i have an 89 aerostar that i had running nicely, i changed wires, coil, plugs (gapped properly), even oil change and filter.
now when i try to start it, it wont go, it has a spark and the fuel pump clicks on.
one thought ive had is the Inertia switch.
also, could it be a faulty fuel injectors..
seeing as the injectors are 128 (canadian) a piece...and there are 6...i hope it is the first thing..
I just had the same situation. I turn the key and hear the fuel pump and then I check the pressure release value next to the fuel pressure requlator and fuel would start flying out. What I didn't realize was, that after that the fuel pump would not turn on. It would do that initial thing and then that was it. Try cranking the engine and hold down the pressure release value, you should have gas constantly being pumped out.
