2017+ Super Duty The 2017+ Ford F250, F350, F450 and F550 Super Duty Pickup and Chassis Cab
My answer to the anoying hitch clatter
Old 03-23-2017, 10:36 AM
Berlin76's Avatar
Berlin76
Berlin76 is offline
I had a buddy make me a reducer that actually fits 3" to 2" going to have it powder coated just quick paint to prevent rust for now
Old 03-23-2017, 11:36 AM
wb6anp's Avatar
wb6anp
wb6anp is offline
He may be able to make money off of that from this forum alone.
Old 03-23-2017, 11:39 AM
44Dan44's Avatar
44Dan44
44Dan44 is offline
Yep, cuz now I'll be first to say, how much, can I get one?
Old 03-23-2017, 11:40 AM
REPO.'s Avatar
REPO.
REPO. is offline
i'd be interested at a reasonable cost.
Old 03-23-2017, 12:01 PM
AK_SuperDuty's Avatar
AK_SuperDuty
AK_SuperDuty is offline
I would be interested as well.
bowler304's Avatar
bowler304
bowler304 is offline
Same here I would buy one.
Old 03-23-2017, 12:39 PM
Berlin76's Avatar
Berlin76
Berlin76 is offline
I can ask but im sure it wouldn't be cost effective. there is a lot of time on this little piece of steel. I really just wanted to share my idea if any of you have machine shop buddies.. this was done using a cnc and a wire machine for the inside hole since its so long.
Old 03-23-2017, 12:51 PM
REPO.'s Avatar
REPO.
REPO. is offline
Reese also makes one. I noticed it on the ETrailer.com website.
Old 03-23-2017, 01:14 PM
Berlin76's Avatar
Berlin76
Berlin76 is offline
I also saw that one but didn't like that it stuck out so far.
Old 03-23-2017, 02:16 PM
oklarado's Avatar
oklarado
oklarado is offline
Technically don't you lose a bunch of capacity going to a 2" hitch?
Old 03-23-2017, 02:49 PM
Berlin76's Avatar
Berlin76
Berlin76 is offline
here is the link to my receiver it claims 17000 lbs I think with the right receiver 2" is really all you need
https://www.farmandfleet.com/product...all-mount.html
Old 03-23-2017, 04:13 PM
oklarado's Avatar
oklarado
oklarado is offline
Yeah you have one of the forged receivers, pretty stout for a 2".
Old 03-23-2017, 08:36 PM
Tomc750's Avatar
Tomc750
Tomc750 is offline
I have a Reese adapter for my 2 1/2 receiver so I can use my 2" bar. It is sloppy and too short. Put it in one way and it sticks out, put it in the other way and it is too far in to provide support. I'll be welding an extension on it as well as a couple of beads so it fits better.
Old 03-25-2017, 12:41 AM
Rasalas's Avatar
Rasalas
Rasalas is offline
One of the problems with making a home-made adapter or hitch extension is the internal weld on the tube and the corner radius of the heavier walled tubes. The weld protrudes into the tube and needs to be ground off so the draw bar can be inserted. Some of the lighter duty draw bars have square corners and will not fit 1/4" wall tubing without having the inside radius machined square. The hitch manufacturers must be set up to perform this machining or a specification for their square tubes not available for off the rack purchases.
Old 03-25-2017, 08:54 PM
Tomc750's Avatar
Tomc750
Tomc750 is offline
Good point - I may just insert the bar before I weld the adapter, and weld the adapter on both ends, thus sacrificing the bar for any further use in a 2"receiver. Interestingly, I have several 2" bars (solid) and the adapter is loose on one and tight on the other such that I had to drive it on. Also, a label on the Reese adapter states it must not be used with a WD hitch, Which I do not need, but oh boy, maybe they just want to sell 2 1/2" WD bars.
Quick Reply: My answer to the anoying hitch clatter
