Are there kits that any of you have used for BBC in an F100? I would want it pretty generic so I could weld together. But starting from scratch seems tedious too. Anyone?
BB uses same type mounts as SB, only difference is BB will need more firewall clearance for the back of the right side head. So you can use off the shelf SB mounts but the installation points on the frame may be different depending on clearances.
