1986 F-150 i6 Carb or electrical problems?
Update
Found this in a 83 would i need this for the swap?
I haven't tested the smoke yet I will as soon as I can get back to it. Thank you all for tour help
but like I said before it starts up fine and cold idles until operating temp then it dies at every stop light. Ill keep you all update on what I figured out.
Are you asking about the wiring or the silver box? That box in the picture is the voltage regulator for the alternator.
If you are asking about a DSII ignition swap. That distributor in your second picture is the correct one for that swap. The ignition module will be a larger aluminum box on the driverside inner fender. Here's a pic of the DSII set up. It should also have the ignition coil and horse shoe connector but appears to be cut off in the picture below.
Yeah I was thinking that would be the box for the conversion but it don't look like it though. I know where the distributor is and possibly the box haven't seen the non feedback carb. Maybe I can get to another junkyard and see what all they have.
The recent things that I have done to my truck is in the pictures besides the last 2 in my previous reply. Just put some balljoints and rotors on it that way it would pass inspection. Shew it was a hastle trying to get the 4wd guts out of the hub and put back in. I survived the test run so I think it will be good.
WalterRoad
03-22-2019 07:31 PM
andrewscofield
29
04-22-2013 01:55 PM
madrox
11-08-2009 11:15 AM
85f-250-460
01-23-2004 09:43 AM
