'00 6.8L with weird issue
The fuel injectors have 12v thru them at all times the PCM has power.
The PCM will individually ground the fuel injector lines thru internal relays to open the injectors.
This makes it easy to test if the fuel injectors are getting power.
Test for 12v at any of the injector connectors on the driver's side when the engine is running since they are all tied together.
The red leads come from a splice in the harness at the rear of the engine which splits to provide power to the 2 banks.
You can test either line at the injector connectors - red is input, various colors are output which would include the injector.
There may be a broken or shorted wire in the harness on the driver's side after the splice.
The fuel rail may be clogged on the driver's side although I can't imagine how.
Can you see if any fuel is in the driver's side fuel rail?
For the PCM to be bad an entire bank of 5 relays would have to be bad which is not likely.
I don't have circuit drawings for the 2000, but in our 2002 the ignition switch needs to be in "RUN" or "START" to trigger the PCM relay which provides power to the injectors.
Grabbed some tools from a friend, and I was wrong, the injectors are firing, it has no power to the coils. I have not dissected the harness yet, but have not found anything externally wrong with it, or anything disconnected. I have also gone back through all of the fuses, even though it appears as both sides are ran off of the same fuses/relays. I'm guessing it has to be a harness issue.
For testing you could run a wire thru a fuse from the battery to the red lead at #6 to see if the coils start firing.
The coils get power from the ignition switch in RUN and START.
They should all tie together in the harness near the back of the engine.
On the wiring diagram there is an "Ignition transformer capacitor 1" for bank 1 and another for bank 2.
Anyone know what they are for?
I'm guessing radio interference suppression.
If one of these capacitors failed what sort of problem could it cause?
I have a friend whose Navigator is also not firing coils on the driver's side.
No, just the driver's side is out, passenger side is firing. It runs on 5 cylinders.
In that case, the harness fault is between splices S130 and S135 shown in the schematic above.
Here's what might be a shortcut:
There's an RFI capacitor on each bank, see both the schematic and the connector layout. Connect a jumper between the two of them (RD/LG wire) and see if the problem is resolved. You can figure out a permanent repair later if you want to or you can just leave the jumper in there and seal it up.
The RFI capacitors can fail in one of two modes, they'll either open (and you'll probably never know it) or they'll short and that SHOULD take out the fuse for the circuit.
#29
You're a day behind, he already confirmed the injectors are working and the problem is due to half the coils missing their power.
#30
