65 F250 heater hose question
1965/66 F100/1100:
Economy fresh air heater has a manually operated heater water shut-off valve: C5TZ-18495-A / Obsolete ~ Available NOS
Deluxe fresh air heater has two cables mounted to a bracket under the dash to the right of the steering column.
C3UZ-18495-A .. Cable Operated Heater Water Valve (Motorcraft YG-133) / Available from Ford, repro parts sellers, auto parts stores.
Both of these valves are located on the fender apron, spliced into the inlet to heater core heater hose, just behind the starter solenoid (relay).
1965/66 F100/1100:
Originally Posted by AZSCAWPION
Valve can be installed in either hose as well. Maybe others can chime in as to which is correct, but I've seen it both ways.
Thanks for the clarification ND. I guess my post should have read that I've seen both connections at the core used as the inlet side (as determined by which was connected to the water pump). I still don't know which is factory correct as I've seen it both ways.
I'd just switch the wires to start. Chances are the aftermarket gauge would work if connected to the original sensor.
You'd be surprised what people do over the course of 50+ years. When I got my truck the PO had connected the ignition switch to the very temp sensor I pointed out. Many other wires connected wrong in a domino affect. Hours of "fun" ensued.
The rat's nest will have to wait until I can pull the seat out. I can't get under there to work on it with the seat in.
My current rat's nest...
I'm uncertain what they did to the fuses...
Joe:
Both holes have the same thread, so you can use whichever temp sender you need and place a 90-degree elbow in the other one for your heater hose. Since the hoses were disconnected...I would almost expect your heater core to leak....watch for water under the dash. If you want to keep a second sender for the factory gauge, you can also get a thermostat housing (water neck) with female threads for an additional sender.
Not familiar with an aftermarket wiring kit, don't have a clue where those wires are running. Should be a single wire running from the water sending unit directly to the gauge and a single wire running from the gauge to the 'constant voltage regulator' in series with the other gauges. Not sure Ford truck wiring manual 65-66 would be of any help; posting link to thread member posted may, or may not find helpful.
https://www.ford-trucks.com/forums/1...e-diagram.html
EDIT:
I still haven't found enough information to troubleshoot the wiring in my truck. I have now ordered the reprinted Ford wiring diagrams (12 pages) from Faxon Auto Literature. It's ironic that I moved to VA 3 months ago from Riverside, CA, which is where Faxon is located. I ordered the 1965 Ford F-100 thru F-750 Truck Wiring Diagram Manual Reprint. Hopefully that will give me enough information to figure out how the truck was hacked.
Never installed the valve, if it would provide additional heat to the cab I probably should?; having said that, routed the hose closest to the inner fender to the water pump, the outer hose to the intake manifold. Believe the valve is inline with the hose that connects to the manifold.
#28
#30
Back to the heater question...
So, to get this back on track after I veered off into wiring problems...
What size is the hose for the heater on a 65? I looked up the part number and became more confused than before. Sure, it's 18472, but...
C9PZ 18472-D is shown for 64 onward as 1/2" ID hose.
And on the same page...
C9PZ 18472-F is shown for 64 onward as 3/4" ID hose.
D1PZ 18472-A is shown for 64 onward as 1" ID hose.
But on the next page...
B8T 18472-A is shown for 64 onward as Preformed 5/8" ID hose.
