At My Wits End. 2014 F150 V8, Hard Shifts
Hey, everyone. Newbie here to this forum. I have a 2014 screw 4x4 v8 that has been in the shop 5 times now for something that the dealership can't duplicate, and that is intermittent enough for me that I can't determine what the conditions need to be in order to duplicate it myself.
My transmission will shift hard under two different situations: 1) when rolling through a stop, or a momentary stop at a stop sign, the transmission holds up between 3 and 1, and when I bring the rpms up, the transmission shifts down into 1, making a hard clunk; 2) at highway speeds, more so when using cruise, if I accelerate and the truck shifts down from 6 to 4, there will be a hard shift as well. In fact, when I'm on a long stretch of flat, open road using cruise at 70-75, I can feel a slight bump through the steering wheel and floorboard, as if the cruise is trying to engage the throttle a bit more, but only for a split second. But that will happen quite a few times within a couple miles until I come up on a grade and the throttle has to engage for a bit longer to keep speed. Sometimes, the hard shift will do occur going to 5 as well, but 90% of the time it will be a 6-4 shift. If the truck decides to shift from 6-3, there's no issue and it shifts and accelerates like it should.
Again, this is so intermittent, but when it happens, it happens several times. I've had the service tech ride in the truck with me, all the while not being able to duplicate the issue. I understand that these are learning transmissions, so the only thing I can think of is when I try to duplicate it by accelerating over and over, that the transmission adjusts the shift pattern or fluid pressure to compensate.
So, hopefully I can get some insight here. Thanks.
have you had the dealer clear the transmission memory? it sounds like it is having a hard time making the transition from the previous owner to your driving style.
I say this not in a derogatory or judgmental way, but it sounds like you drive with a rather heavy foot. I have found with my 2010 that the transmission gets confused if drive hard after I've driven very lightly for a long time.
I realize things are different from 2010 to 2014, but a 6-4 downshift for me is rather rare, and a 6-3 downshift is very very rare, and only happens if I go nearly to the floor in a very abrupt manner. for me, even a 6-4 downshift takes a lot of throttle input quickly.
to clear the memory, you could try disconnecting the negative battery post and jumper from the positive to the negative with a small jumper wire and let it sit for a few minutes (be very careful to insulate the negative post when you do this so there is no connection to the battery) this will kill any capacitive memory in the truck, but as I understand it, the transmission strategy is kept in a PROM which is supposed to be retained when the battery is disconnected, so it may take a programmer to actually clear the transmission memory.
but the jumper wire is free to try
I may have a heavy foot at times, but honestly I can say it's not hard starts from a red light or anything. It tends to be more on the highway, but even then it's not to the floor. It's just enough to accelerate around someone or get on the highway itself. More than anything nothing, I battle that green bar to try to keep my MPGs up as much as possible. One thing I have read is that if the tranny is shifting hard, that I should drive it like I stole it for a while and it will resolve itself. I just don't feel like that is and viable option in order to get shifts as smooth as my old 2000 Explorer.
One other option I've read is an aftermarket tuner from SCT, but not while I'm still under warranty.
well, there goes my theory
a tuner may help, but this seems like something unique to your vehicle. I haven't seen many similar complaints leading me to think it is just a general programming issue.
how does it drive with the tow/haul engaged?
any better or worse with regard to shifting?
I've had similar hard shifts happen on 6-5 and 6-4 when on highway. Usually this is with a "roll in" on the throttle vs. stomping on it. It hasn't happened enough for me to look into it - just wanted to mention that you are not the only one with the problem. Hope that you are able to resolve.
I did utilize the Tow/Haul feature about an hour ago and it did seem to hold it in gear better instead of trying to down shift. Basically, it felt like the way a transmission should feel.
Nothing from me...
If it drives better with tow/haul id just do that....
I realize thats not what you want to hear, but as far as practical solutions go, pushing a button is about as practical as it gets for me.
You've tried having it recalibrated by ford, so I'm not sure what else to try.
Unfortunately, even though the transmission is quite smart, it's also ALWAYS in learning mode. There are too many variables at play to determine what causes what, even though you are able to repeat it. Clear the memory from time to time and it should even out. I found that with my former truck that the frequency of flashes for tunes would keep the trans pretty happy as each flash would clear the KAM.
Did you try this:
If not, then I'm "at my wits end" with your willingness to try.
Also, I believe I shouldn't have to reset anything on a $40k truck in order for it to work right. Especially when I hear no complaints from others.
I dont think you hear many complaints because we've all gotten used to it.
One of those "just the way it is" kinda things.
Here's some of my thoughts on it
https://www.ford-trucks.com/forums/1...11-better.html
https://www.ford-trucks.com/forums/1...h-2010-xl.html
Do an advanced search in this forum for posts I've made about the transmissions in these trucks.... You'll find about 8 pages of stuff to go through. In there you'll see I've described fords adaptive shift strategy as "riding the short bus"
Ford Truck Enthusiasts Forums - Search Results
I just don't complain about it anymore ... It is what it is.
