Rear end whine
Rear end whine
I'd just pull the diff cover and check it out. You might have some metal shavings loose in there. I'd check the gears to see if it was shimmed correctly as well. On each tooth of the ring gear there should be a small rectangle in the center of the tooth where contact occurs.
When you are done, refill the diff and make sure to include some LS additive.
Rear end whine
After I bought my truck I became aware of a whine in my rearend. I took it to the dealer and they had to add the LS additive. The dealership that I bought my truck from had serviced the truck and had changed all the fluids. Obviously they didn't add the additive. This fixed the whining problem in the rearend.
edselman
08-30-2004 05:21 PM
