Need to pull dash, How do I get the headlight switch out?
Pull the **** out. Turn it until you see the slot on the throat of the ****. Once you find it, use a "fine line" regular screwdriver and drop it into the slot. PULL the screwdriver tip TOWARDS you. Once it pulls against the **** retainer, pull slightly on the **** while still pulling with the screwdriver. It should pop right off thus allowing the dash assembly to come right off. good luck. Jake.
Yea, excatly what they said. Here is a picture to clairify. Put the screwdriver where the red line is.
Second pic is incase you can' get the rest of it off.
http://members.tccoa.com/charlez/images/****.jpg
http://members.tccoa.com/charlez/images/fdash2.jpg
One screw on each side.
