Have 81 f250 4wd custom with 5.8 351m
Im buying set of moto metal wheels 16x8 with 0 offset . And then getting a set of 305/70r16. Do i need a lift with this combo or am i good with stock ride height ?
Yes . If necessary ill get some spacers but i just need to know about the lift. The tires im putting on are 33s and im changing the shocks but dont know if i need to lift it any
I used to run 33x12.50-16.5 tires on my stock '84 F-250 without a lift and had no trouble with them rubbing. It looks a lot better with some lift though because those tires will pretty well fill up the wheel housing. You can lift these truck but you need axle drop brackets to lower the end where each half pivots.
