1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Dually Spacers ?
Old 01-12-2017, 09:18 AM
Papa Charlie's Avatar
Papa Charlie
Papa Charlie is offline
Dually Spacers ?
I have a 2003 F350 4x4 Dually and want to put larger, wider tires on without going to 19.5 or 20 inch wheels.
I have heard horror stories about dually spacers for the rear wheels but see a lot of people using them. Different comments is that you cannot use the truck for towing or hauling heavy loads, they will break, only good for looks, etc.
What is the truth about these. Is there solid made spacers, preferably made of steel that will not de-rate my trucks payload capacity? Is there a limit to the space that you can go before you affect the trucks capacity?
Your help would be greatly appreciated.
Old 01-12-2017, 10:43 PM
wxherk's Avatar
wxherk
wxherk is offline
papa.....I have a new set of spacers that I bought for my 2002 F-350 that I no longer have if you are interested......Chris
Old 01-13-2017, 12:20 AM
Mike189677's Avatar
Mike189677
Mike189677 is online now
If you do this spacers need to be hub centric not lug centric and of good quality made in the USA. The saying you get what you pay for definitely applies here.
Old 01-13-2017, 08:15 AM
Papa Charlie
I was thinking the same thing. Would like to see if anyone has used them or know of people that have used them, especially the steel hub concentric units. I have heard that the aluminum ones can fail, steel would be the only way I would go.
I don't put that much weight in the back of truck, used mostly as a daily driver and to tow an RV.
Old 01-13-2017, 08:35 AM
Ron94150's Avatar
Ron94150
Ron94150 is offline
I was opposed to spacers for a long time. But I've done a lot of research on them. Quality steel spacers are fine, if installed correctly, and there's nothing wrong with quality bullet spacers of the correct alloy. Here is a sight that sells quality spacers.
http://www.motorsport-tech.com/4DCGI/switchtruckmodel
Cheap spacers are not hub centric. Improper install and not correctly checking torque is the most common cause of failures.
wta
01-18-2019 04:01 AM
Joseph Nazeck
05-31-2012 01:15 AM
whitesdford
02-25-2010 07:28 PM
6.0king
03-13-2007 08:33 PM
Quick Reply: Dually Spacers ?
