front motor mounts: 52 L6
Here's what was left of the motor mounts I pulled off the truck:
I was able to find new/repro rubber pieces. I've come up with nothing on the dual diameter bolts & metal cups. If need be, I figure I can make the bolt, just be patient and use a bolt, grind it down and run the correct die over it. I assume the right diameter thrust washers are easy to figure out. That just leaves those metal cups with holes in them: do they need exact reproducing or can they be improvised. Anyone else run into this?
Thanks!
John
Thanks!
John
Thanks Stu, the Carpenter site specifically lists that bolt only to 1951 but now I see it's the same part number so just grabbed them. I'll be putting in a motor in a few days!
That's one beautiful build you have doing there! What material is that for fuel line? Braided? It's a little blurry in the pic.
John
John
2C-6047-A .. Engine Front Support Insulator Bolt / 1/2" -20 x 3.40" long hex head / Obsolete
1952 215 I-6 trucks / 1952 239 V8 trucks / 1952/53 254 I-6 trucks.
MCDONALD OBSOLETE PARTS in Rockport IN has 1 = 812-359-4965.
NOS PARTS LTD in Waxahachie TX has 2 = 972-937-2201.
OBSOLETE RELIABLE PARTS in Nashville GA has 2 = 229-686-5101.
Look at Ross' Ford truck parts catalog pic in post #2, maybe Carpenter sent you B-6047 for 1948/51 that is 7/16" -20 x 2.97" long.
Jesser02EX
05-14-2016 11:26 AM
Damifiknow
03-30-2014 08:25 PM
daddyjustang
08-02-2010 11:11 PM
Abomination
06-06-2009 03:21 PM
