Dana 60 Manual Hub Conversion
I have been doing a search and can't seem to find a clean write-up on this one. I know we need the spindle kit? I am going with Warn Premiums. I don't know yet if I have the 30 or 35 spline, but I figured I'd find out by taking the cap off and counting them. LOL
Anyone know what the kit might be or better yet, have a link to a thorough thread on the conversion? Thanks.
You have 30 spline axles like every production dana 60
You will need a way to remove the old auto locking hub nut. That uses a 2-3/4" socket.
The manual locking hub's nuts uses a 4 prong socket. It is approx 2-1/2" diameter.
As for the locking nuts themselves. WARN, AND MILEMARKER both make them. Stage 8 also has a nice set as well
Originally Posted by madpogue
Weren't the OEMs made by Warn? I've got OEMs on my '85, and except for the brand, they don't look a lick different from the Warn standards.
Well now I have heard two different camps say each one of those hubs is junk and not to put them on the truck so I'm not sure what to do. I'll stick with Warns if I can't find a set of OEM for the Dana 60.
I have had one Warn go bad on me but I'm not entirely certain it wasn't my fault; I may have left it partially engaged. But that didn't matter as they sent me a brand new set for free. So at least their customer service is still top notch.
If you want a set of OEMs, go find yourself an F250 Dana 50 in the junk yard.
^^^^ Similar experience. We had one Warn get hung up. It was the plating on the outer cap, interfering with the dial that you turn. Swapped out both on warranty, took all of 15 minutes (if that) to swap. Local 4x4 shop where we originally got them had a set in stock, so it was a no-wait swap. I have no basis for comparing them with anything else.
And no, the OEMs on my '85 are staying on my '85; like the truck itself, they're not for sale.
Yep, D50 and D60 hubs, bearings, studs, and lockouts are the same. My local yard always leaves them on the trucks because no one wants the ttb stuff. BTW, don't scrap your auto hubs either; some people really like them and they will sell pretty quickly on ebay.
#30
