FORScan for Tire Size changes
https://www.ford-trucks.com/forums/1...lt-data-6.html
Page 6, post 77
I can't say it's been confirmed, but he's done a lot of great work finding these options.
Go to the first page of the post. I reference a great post from member livinitup from F150Forum. Tons of info been a great help.
Keith
OK, dredging up an old thread here but it's the most closely related to what I want to do.
Thought maybe to bring it back to life would save some clutter on the general FORScan thread.
Check out the link in post #3. Has anyone done this for tire size change? I currently have 275/65R18 tires that are 32.1 inches high. I'd like to go to a 34 inch tire to fill the wheel well a little better as well as have a more aggressive tread than the Continentals that are on the truck.
The table listed below shows a value for 275/65R20, which is exactly 2 inches higher (34.1) than my stock tires. If I could find a 295/70R18 it's 34.3 inches, probably close enough for speedometer accuracy.
A couple of other 18 tire sizes measure out to 34.6 and 34.8. I could even do that if the BCM had the values somewhere in it for FORScan to change.
Any information on this is appreciated. As soon as I know for sure what I can do without setting a malfunction light, I'll get some tires ordered.
Here's the graphic link from thread cited in post #3 of this topic:
Attachment 196067
Attachment 196067
Attachment 196067
Attachment 196067
Let us know if this helps.
Keith
I would start by selecting the largest "stock" tire size available. Then cross check accuracy with a GPS. On your reference chart look at the last line in the tire size area, you see the ABCD. To the right is a link to a custom size page calculation. You can go any size you want for total accuracy. Keep in mind that if you get outside the variance parameters you will most likely set a P160A code. ForScan only writes to the BCM here. There is a reference in the PCM that we don't have access to yet. As I recall.
Keith
Keith
But if those codes shown hold true, I could go with a 295/75R18 at 34.3 inches and use the code for 275/65R20 (34.1 inches), which would put it within 2/10 of an inch.
Also, the FORScan speadsheet we're all using shows that a person bought 285/75R18 (34.8 inches) and used a code for that size that appears to work for him. But he was only bumping up from a 275/70R18 (33.2 inches).
So he went up 1.6 inches. If I were to go to that same 285/75R18 I would be moving up 2.7 inches. I'm wondering if the larger difference would affect accuracy or cause the P160A?
I want to get some tires, but I want speedo accuracy. These figures are making my head hurt!
Keith
Keith
Hey guys. I went from factory 18” continental contitrac to factory 20” wheels and factory size option with KO2 275/65/20. Tires were mounted at the dealership and I walked the tech thru IDS to changed the size. After a few days I felt I was going faster than others at posted speed. I doubled check with 2 phone apps simultaneously. Sure enough it’s off. 5-6%. Don’t know if it was accurate prior to making the switch. Trying to get my hands on a gps to be more accurate. Oil change coming up within 2-3 weeks so I will be discussing with the tech again. Was the 1st one to make a tire change so they won’t have much history there. I did receive my ordered OBDII dongle for forscan. That will be the next step... just a little scared to get into this haven’t had time yet to understand the proper steps. But there is a few items I’d like to knock off that forscan list once once I’m comfortable !!
The ABCD link appears to only lead to a page with the same chart. I don't find any additional info on tire size values.
https://goo.gl/kKm5uw
This link is from the 11-16 SD ForScan Sheet.
I have confirmed it works.
https://docs.google.com/spreadsheets...s1s/edit#gid=0
Also, ask questions here of the experienced people. Everyone so far has been willing to help out a rookie like me.
OK try this link.
I also stumbled upon a link for F150s where the PCM could relearn after BCM reconfiguration with FORScan to remove the MIL. Of course now I can't revisit it! Nor do I know if would work on 2017 F250s.
My hat is off to those who have done all of the experimenting and provided all of the information that we currently have.
