Had a very tough time driving in the snow - thoughts ?
I did a lot of front end work listed below. My 4x4 was broken which of course made it harder driving in the snow but here are a few things I had issues with,
1. When I went to turn, the truck hard trouble turning and wanted to slide straight.
2. When I was sitting in traffic... the truck kept "sliding" off the road. I would be still and then the truck would start sliding....yet the cars/trucks infront/behind me didn't slide.
What could be the causes of this ?
Some of the front end work I did was,
> Ball joints
> New drag link
> New steering rods
I'm pretty sure my alignment is "decent".
> Ball joints
> New drag link
> New steering rods
Tires are definitely the issue....I had junk tires on my Cummins and exactly the same issue.....I had brand new tires Cooper Discoverer AT/3's on my Duramax and they sucked too....I have yokohamas on my 6.0 and drove it in the snow twice and the truck never ever had an issue.
If the truck will be 2wd for the winter, I would throw a set of studded snows on the back(if your state allows it) and you'll be amazed
1. My hub lock broke so the new one is coming in this week.
2. I attached some pictures I just took of my tires now - seems like decent thread... am I missing something ? Thanks.
A limited slip will act like a locker. Both rear wheels will push you thru things. As for the rear sliding at a stop soinds as if the rear brakes need to be adjusted. The rear tires are turning while your sitting at the light stopped. You will only have this happen in really slick situations. Weight in the rear helps but i think the limited slip is causing most of the issue turning think of how a tractor turns and why theu use cutting breaks
I bought new brake pads online.. the front pads were far thicker than the rear.
Wouldn't it be safe to assume since the front pads are thicker than the rear.. once I am stopped the rear pads aren't "gripping" as much as the front ?
Also, the ABS brakes kept activating very easily this morning in the snow.
Is this all related ?
Thanks
Tires. Could it be your brakes?? Maybe but I bet it's your tires. What PSI are your tires??? I bet they are over inflated. Try taking your truck to a tire shop that can sip all 4 of your tires for better traction. If all those things are done with no improvement, I would say that your tires aren't good for snowy conditions, most likely due to the compound(Betting that when cold it gets too hard). Anyways, let us know man!
I think I know why... correct me if I am wrong.
Thanks
Thanks
Another +1 for the tires. I suffered the same a long time ago in a company work van. the boss was cheap and bought the cheapest crap tires ever. The front end would slide towards the curb when stopped when no one else did.
I also had a Mustang decades ago with some low profile Dunlops on it. In the summer those things were like sticky rubber. As soon as it got cold I was on slicks. It was the compound.
