Where is the water going ???
I have a 2007 , 6.0. About a month ago the gauge went into the read while in line at bank , soon as the alarm went off in a matter of a minute the gauge came back to normal. when I got home the coolant tank needed pax a gallon water .... about three days later it need about another 1/2 gallon to fill it to full line ..... after driving it about 20 miles it sat in the Driveway for a few days .... I checked it again and it was full. I loosen the top of the tank and it had pressure still on it after all these days ,,,,, ( this tells me I have no leak) ..... well for three weekends in a row I drove it to the camp (350 miles) round trip with no issues. Never did check the water level in the tank during this time ,,,( I know dumb move) ...... well coming home from camp today it ran hot again. Had to add about 2 1/2 gallons of water / coolant to get it full. Ran for another 2 1/2 hrs to get home with no issues ..... get home and unscrewed cap and it had pressure and needed about 1/2 gallon in tank to refill. This truck has 145,000 miles on it. Hardly driven except during hunting season. I have a company truck for everyday driving to work etc. what are y'all thoughts. I will park it over a cardboard flat to see about a leak. Driveway is rocks. Someone said it may be blowing it out thru the tailpipe. God I hope not .....
Thanks
Thanks
Really a few different options here.....
If you have a stock EGR cooler, it could be going thru there, and burning up thru the exhaust, park the truck nose down over night pull the EGR valve and see if its wet-but I feel 2.5 gal would be noticeable thru the exhaust
The little hose that connects the EGR cooler to the oil cooler housing are prone to leaks
Or it could be the head gaskets
If it were me id make a pressure gauge for about $15 and check cooling system pressure...
Everyone assumes coolant issue means blown head gaskets...not true
unregistered guest
09-04-2014 08:35 AM
esodemann
1999 to 2016 Super Duty
10-25-2013 01:38 AM
Justinbel4
09-17-2010 04:43 PM
