Weigh Safe Hitch Group Buy
#106
Thanks for setting up the discount. I went with the 8" drop. I picked up a 5 1/4" drop at home depot for a small ATV trailer and it's perfect. The trailer is my friends and he has a trailer that is even lower so I figured I'd do the 8" over the 6" for a little more headroom.
Glad it worked out for you!
#107
#108
#109
#110
on
Measure distance of the ground to the inside base of your receiver (R) and also the ground to the inside top of the ball coupler of the lowest trailer you'll pull (T). In my case R was 3 inches higher than T. So then you have to determine the amount of drop (D) and then rise from the base and ball assembly (B) so the ball will be at the appropriate height to attach to the trailer and keep it level when empty or loaded. Write down these values and use the following math to figure out the drop length needed for your setup.
In my case, my receiver is 21 inches off the ground (R=21). So if I get an 8 inch drop hitch (D=8) with a 6 inch base and ball assembly (B=6). R-D+B=19. 19 inches is the net height above the ground of the top of the ball when using an 8 inch drop hitch. Trailer tongue height is 18 inches off the ground or (T=18). So the ball is exactly one inch higher than the trailer ball receiver. Hook up the empty trailer and the back end of the truck sags one inch and whalaa! You have the correct drop amount for an unloaded level trailer or maximum drop needed on your drop hitch. As the weight of the trailer increases, raise the ball assembly before connecting to compensate for sag. Draw out these values on paper and you'll see it works perfectly every time.
#112
I ordered from Truck Monkey Parts late Thursday afternoon and it hasn't shipped yet. Checking the status on their site shows it's ready to ship.
#113
#114
#115
Had to settle for 2.5 inch weigh safe
After much hand wringing and trying to figure out how to justify the 3" weigh safe, I ordered the 2.5" - it's the largest receiver size that still accommodates the hitch-mounted Rock Tamers (or any other brand of mud flap systems for the matter) that attaches to the receiver shaft. 2.5" is also the size of the "stinger" on my ProPride 3P weight distribution hitch that I use for the Airstream.
I suppose if ProPride or Rock Tamers ever produces 3" product, then I'll be back in the market...Thanks everyone for the great information and help. BTW - the discount code still worked at Truck Monkeys for the 2.5".
#116
I was excited, then weigh safe said it was machined from a solid steel block of aluminum and my 'wait, what?' flag went up. The guy in the interview asked if it was a special aluminum alloy that resists corrosion. Weigh safe did not correct that, they just mentioned it was machined from 6061 T6 which is a very common lower cost aluminum alloy.
Nothing wrong with 6061, but there are aluminum alloys that are stronger and more corrosion resistant.Not saying its not a great product, they cost less than other hitches that's a plus.
#118
#119
#120
On my 14 F 150, I used the 2" drop on almost everything I had. Car trailer, 14' enclosed, dump trailer, and others..
