THE CREAM PUFF PROJECT......
Its definitely not factory. It has the round 3"DP. I do know that the other night we were working on removing the turbo, etc so we could get everything ready to install the new pedestal and high flow and when my husband got up under the truck he was having a fit! He said someone "chicken welded" (his words lol) the piece that we need to remove instead of clamping it. He gets frustrated sometimes because it seems like no one pulled any maintenance on my truck over the years and every time we fix one thing we find something else wrong. But as soon as we get the truck mechanically sound it will last me forever! And after the mechanical stuff is done then the fun stuff beings...we will tear the bed off and start sanding and fixing blemishes and getting it ready for new paint! Cant wait!
UPDATE TO THE CREAM PUFF PROJECT.....
FUEL PUMP…..$98.87
COMPLETE FUEL BOWL ASSEMBLY….$299.98
IPR….$184.81
SINCE 11/26/2016 WE HAVE REPLACED THE VALVE COVER GASKETS, THE UNDER VALVE COVER WIRE HARNESS’, WE HAVE THE DELETE BLANK PEDESTAL PUT TOGETHER JUST NOT INSTALLED BACK INTO THE TRUCK YET, WE HAD ALSO FOUND A FUEL LEAK IN THE VALLEY OF THE ENGINE AND WHILE SEARCHING FOR THAT NEW PROBLEM WE DISCOVERED THE FUEL BOWL WAS BROKEN. SO AS OF NOW I HAVE NEW PARTS SITTING IN OUR SHOP WAITING TO BE PUT ON…..NEW OEM COMPLETE FUEL BOWL ASSEMBLY,A NEW FORD IPR, A NEW FORD FUEL PUMP (ALONG WITH ALL THE HOSES ETC).ALSO, SINCE THE END OF NOVEMBER I HAVE BOUGHT FRONT AND REAR OEM BUMPERS (USED BUT IN EXCELLENT SHAPE), A USED GRILL, USED HEADLIGHTS/PARKING LIGHTS,DIFFERENT MIRRORS FROM A FORD TRUCK, A HOOD IN EXCELLENT CONDITION.I DIDN’T NEED A HOOD BUT DECIDED THAT WHEN I COME ACROSS OEM PARTS IN EXCELLENT CONDITION (FOR A CHEAP PRICE) I AM BUYING THEM.WAS REALLY HOPING THAT WE WERE GOING TO HAVE THE TRUCK PUT BACK TOGETHER AND RUNNING IN OUR SHOP BY LAST WKND BUT IT WAS 4 DEGREES ALL WKND AND THE SALAMANDER HEATER BARELY TOOK THE CHILL OUT OF THE AIR.THIS WEEK WE ARE GOING TO HAVE A FEW 45 DEGREE DAYS AND WE WILL MAKE SOME GOOD PROGRESS (GOTTA LOVE INDIANA WEATHER! FRIGID ONE DAY AND SPRING LIKE THE NEXT!)AS SOON AS EVERYTHING IS PUT BACK TOGETHER WE ARE GOING TO SIPHON OUT ALL OF THE OIL FROM THE TRUCK AND START OVER FRESH AND ADD HOT SHOT SECRET.I AM GETTING REALLY REALLY ANXIOUS TO GET MY TRUCK RUNNING BECAUSE ONCE THE TRUCK IS MECHANICALLY SOUND THEN WE CAN START SANDING AND PREPPING FOR A NEW PAINT JOB AND I AM GOING TO STRIP THE BLACK PAINT OFF OF MY ALUMINUM RIMS (WATCHED A FEW HOW TO VIDEOS YOU TUBE).IT SURE DIDN’T TAKE LONG TOGET OVER $2,200 WRAPPED UP IN MECHANICAL FIXES AND THAT’S BEEN DOING 99% OF IT BY OURSELVES!I AM SURE HOPING TO GETATLEAST ANOTHER YEAR OF NICE WEATHER DRIVING OUT OF MY INJECTORS THAT WAY I HAVE ALITTLE TIME TO SAVE UP FOR THE INEVITABLE. I AM ALSO RESEARCHING LEVELING KITS AND SCANNERS AT THIS TIME.
FUEL PUMP…..$98.87
IPR….$184.81
Since 11/26/2016 we have replaced the valve cover gaskets, the under valve cover wire harness’, we have the delete blank pedestal put together just not installed back into the truck yet, we had also found a fuel leak in the valley of the engine and while searching for that new problem we discovered the fuel bowl was broken. So as of now I have new parts sitting in our shop waiting to be put on…..New oem complete fuel bowl assembly, a new ford ipr, a new ford fuel pump (along with all the hoses etc).Also, since the end of November I have bought front and rear oem bumpers (used but in excellent shape), a used grill, used headlights/parking lights, different mirrors from a ford truck, a hood in excellent condition. I didn’t need a hood but decided that when I come across oem parts in excellent condition (for a cheap price) I am buying them. Was really hoping that we were going to have the truck put back together and running in our shop by last wknd but it was 4 degrees all wknd and the salamander heater barely took the chill out of the air.
This week we are going to have a few 45 degree days and we will make some good progress (gotta love indiana weather! Frigid one day and spring like the next!)as soon as everything is put back together we are going to siphon out all of the oil from the truck and start over fresh and add hot shot secret. I am getting really really anxious to get my truck running because once the truck is mechanically sound then we can start sanding and prepping for a new paint job and I am going to strip the black paint off of my aluminum rims (watched a few how to videos you tube).It sure didn’t take long to get over $2,200 wrapped up in mechanical fixes and that’s been doing 99% of it by ourselves! I am sure hoping to get at least another year of nice weather driving out of my injectors that way I have a little time to save up for the inevitable. I am also researching leveling kits and scanners at this time.
https://convertcase.net/ works wonders if you forgot caps lock on
10char
I didn't see you mention this so I figured I'd ask just in case.
What type of anti-freeze did you add? If you used conventional green coolant and distilled water (ONLY USE DISTILLED WATER IF ADDING WATER TO FULL STRENGTH COOLANT), did you make sure to add the SCA coolant additive?
These motors require a special additive in the coolant to prevent cavitation. I believe the cavatation happens near the cylinder walls and coolant passages and can eventually lead to irreversible damage. This happens due to the large compression and vibrations these motors produce, which doesn't happen in your standard gasoline engine. You can get the additive at O'reillys or probably Napa and get the test strips for the additive at Napa as well!
https://www.amazon.com/Motorcraft-Di.../dp/B0065SZU8I
