plug AE into OBD II
plug cord into laptop, then into AE
Key on
Open program
under Vehicle, open communication configuration
select USB-J1850 PWM-NON OBDII only
under vehicle, connect-Ford-year
model is powerstroke 7.3
enhanced powertrain
yes i have talked to them and they said it was a chip or the pcm is locking it out .I'm not to happy. it works on my 2002 7.3 work truck,my wife's 2006 F-150 and the boys 1999 ranger but I don't want to play with them. I did not check fuse but i can charge a phone through the lighter. what do I do now?
Reason: cuz
I have the same problem yesterday. Bill @ AE said the reason it won,t connect is because I have a DP tuner chip . I just received the new F6 chip 2 days ago. Tried to connect no luck. It was to late to phone Jody & I believe they are closed on Friday. Will try to-day without the chip.Friskyjake
OK I went out & pulled my Dp chip. Connected my AE to the ob11 port Turned on my key to on. The AE would not connect, Truck would start & run without the chip installed. Put chip back again ,hooked up AE & it would not connect to read anything. I have pulled chip again. Left it that way till I can get some good help. Before I tried all this I checked both, power output & cigar sockets have power & the OB11 port has 12.5 volts {lower R side pin} Will be asking for any advice form you folks & Jody @ DP tuner & try with AE on Monday. Friskyjake
