1988 Ford F250 460 BB wont fire
Will
That's generally indicative of a power problem to the computer, or a computer issue. However your fuel pumps cycling seems to indicate otherwise. I know some early EFI models didn't have a check engine light.
Anyways, so you definitely hear the fuels pumps running after a start attempt, right?
If the truck has sat for a long time you may have to clean all the injectors before it will run.
If it has not sat for a long time then either you have bad wiring to the fuel injectors or a bad computer.
Make sure the small black wire with a green stripe has a good ground connection at the NEG post of the battery.
The large NEG cable goes to the engine block and not the frame.
And make sure there is also a large (10ga) wire from the NEG post or engine block to the body.
You verified the injectors have 12 volts at them? If so, that means the computer is not even trying to fire the injectors.
I recommend purchasing an Innova 3145 code reader. They're about $25.
Just to verify about the pumps again:
When you first turn the key on, the fuel pumps only run for 1 second, then turn off, correct?
When you turn the key to "Start", then let go, you should hear the fuel pumps run for 1 second then turn off. Is this correct?
Will
So as of right now, it looks like there is either:
A, there's open circuit between the injectors and the computer (the computer grounds the injectors to fire them), but it seems unlikely both would go open circuit (unless something ate the wires).
B, the computer is faulty
or C, There is a sensor issue. Generally there is only one sensor that can prevent the injectors from firing during start up, and that's the throttle position sensor. You can try unplugging it, and seeing if it will start.
Being able to check for codes will be a big help, however.
Will
Do your diagrams state whether or not the 88 460 has a check engine light?
#30
The Dark Blue wire:
