High Beams only work on pass side. Help
I have been racking my brain on this headlight question. On my 59 F100. The low beams work fine. When I hit the dimmer switch the passages side highbeams go on. the driver side outer light goes dim and the inner light stays off. I have swapped bulbs I have put a volt meter on the wiring inside the hood. both red and green wires have 12 volts when appropriate. What am I doing wrong. I have a wire diagram could it be the dimmer? although shouldn't that affect both lights?
loyal
Electrical Systems/Wiring
06-14-2009 03:46 AM
RyanMiller
05-25-2005 09:15 PM
imlowr2
12-09-2004 05:44 PM
