65 4x4 F100 9" axle spline count
An "08" axle code would be for a 28-spline, open (single track), 2-pinion differential with a 3.50:1 gear ratio.
A 9-3/8" 3rd member is easily identifiable from a 9-inch 3rd member. The 9-3/8" 3rd member will have two widely spaced vertical ribs on the front with a top horizontal rib that curves downward on the left side --as seen in the following photo.
A conventional 9-inch 3rd member (after about 1960/'61) will look like this.
A Ford 9-inch N-case (nodular iron --the ultimate in Ford 9-inch 3rd members for strength) will have two vertical ribs more closely spaced than the ribs on the 9-3/8" 3rd member but, the horizontal ribs on the N-case don't curve downward at the ends --31-spline 4-pinion Traction-Lok differential 3.50 geared Daytona N-case 9-inch 3rd member pictured on the right in the following photo. My old "08" axle code '69 F100 C7AW-E casting 28-spline single track 3.50 geared 3rd member on the left.
From 1957 to about 1960/'61, the Ford 9-inch 3rd members were cast from a weaker gray iron material. These 3rd members were more prone to breaking where the input driving pinion housing is. The 3rd member casting numbers for any of the 3rd members mentioned here can be found on the inside of the 3rd member, next to the right hand differential side bearing stand.
The weaker gray iron 9-inch 3rd members look very similar to the N-cases but, there are notable outward differences between them if you know what to look for. The more undesirable gray iron 9-inch 3rd members will look like this.
If you come across a 9-inch 3rd member you think is an N-case and you see these letters inside it (WAR, WAA or WAB), it's not an N-case. It's an older gray iron unit.
Any 9-inch 3rd member (car or truck) will fit in any 9-inch rear end housing. The differential spline count just has to match the spline count of the axles for the particular rear end housing the 3rd member is being used with. The companion flanges (where the driveshaft attaches) are generally longer on passenger cars and shorter on the trucks.
ridealong34
09-25-2016 08:30 PM
simnathan
03-31-2013 06:31 AM
