Best oil for quiet running?
I use to own a LMM duramax (2008 LTZ 2500) and it came with rotella 15w-40 when I bought it with 18k miles....once it cracked 5k miles I changed the oil with an a/c delco filter and Rotella T6 5w-40. As soon as I started the engine I got the dreaded typewriter tick for the next 5k miles. So like any consumer I started reading up on what oil stopped it...well long story short, next oil change I put in a Amsoil EOA oil filter and Amsoil Diesel Syn 5w-40 and sure enough the engine quieted down and the tick was gone.
I'm not an advocate of Amsoil but I can't complain about real life results. Once my new 16' F250 is down and over with it's 2 years of free oil changes, I will be running that same EOA oil filter and the same Amsoil diesel 5w-40 oil.
I just did an oil change with T6 5-40 with Motorcraft filter that I've also used for the last few changes. It's noisier now than before the change. Sounds like an old 7.3 sometimes.
I'll try Amsoil for the next change if it'll help the noise. I haven't been running an additive in the fuel although I have some here.
Keep hearing about Amsoil and want to give it a try. I have been told that its good way past the recommend change interval.
With that in mind do you both stick to the recommend change alerts or go further?
Depends if you have emission equip and warranty. The only reason they recommended the manufacture interval is due to the fuel dilution possibility caused by regens. I am however just going to change when my light comes on and keep receipts in case of any future warranty issues. So I guess if you were deleted and off warranty you could go much longer.
#28
might sound strange, but have you had your windshield replaced? I had a POS company here in Florida change my windshield and even after telling them it needed the soundscreen windshield they put in the other. Notice a little more noise, but we get windshields for free here in Florida and State Farm is going to make them change it just haven't got around to it yet.
Just an Idea
Just an Idea
#30
That doesn't surprise me. Cetane does the exact opposite as octane does for gas. It makes diesel MORE volatile.
