OT home buying
#198
Todd,
do you have any suggestions or tips for using
https://www.lowes.com/pd/Castlewall-...1-5-in/3043801
I am looking at 13-14 courses for the retaining wall...I got about 200 of those for free....okay fuel to go to fort wayne and get them..
Or is there something better?
#199
#201
#203
The virgin ground probably wont happen...With the power, gas, water, cable and phone lines running through the middle of my front yard, not to mention the tree I have to take out...and the current anchors that are in the ground now holding what is left of the wall in place..
#205
I personally wouldn't use those blocks. I don't like the way they look at all and there are better products out there. But everyone's budget determines a lot in any project. Here's a real simple idea of what you're in for.
For the first course (this will be buried)
get down to hard clay
6"-8" compacted crushed limestone (57's)
1/2"-1" of limestone screenings (9's)
Start laying
Backfill as you go with 57's. I wouldn't worry about landscape fabric unless you hit iffy ground. We have such hard clay in Ohio it makes a great base. You'll want drain tile behind it. Unless you rent some machines, you've got lots of handwork ahead of you. How long is the wall? A laser is HIGHLY recommended.
Start laying
#206
#207
I personally wouldn't use those blocks. I don't like they way they look at all and there are better products out there. But everyone's budget determines a lot in any project. Here's a real simple idea of what your in for.
Start laying
Start laying
Thank you!
#208
A lot of the larger retaining wall block are about 80-90lbs. They have open "webs" much like CMU. Fill with 57's as you go. If you go with something that has a set back like that with an open web, you'll need to put a cap on it.
Go to a place in cinci called Reading Rock. Check out what they have. They're on the cheaper side vs a company like unilock, but we use their products on 200k patios. So just fine. If there is something you like, let me know. I can try to put in a word with the salesperson.
They also offer a class. Not sure if it's just for industry guys or not. May want to check it out.
#209
Sweet they are just down the street from me, I will have to run by the yard next Saturday!
#210
