2017 vs 2016 Height
I stopped at a dealer Sun and they had two F350 CCSB 4wds(1-'16 and 1-'17)sitting next to each other. Both had 20" wheels and the 6.7, the '17 was slightly higher than the '16.
Tops of the cabs had maybe 2" difference.
The top of the box was quite a bit higher on the '17 but it looked like the '17 had deeper bedsides than the '16.
Bottom of the cab on the '17 looked quite a bit higher but I think it's more of an optical illusion because of the way the cabs are designed.
Look.....
Had to remove trim from my garage for it to fit.
Look at the opening behind the bed. Not to mention it's 3" longer as well.
If you live in a snow state, don't forget that you'll hit if there is significant snow on the ground. That would be a bad way to end or begin the day!
