1997 Explorer "E" 4.0 to "X" 4.0
If it all goes to gather and works yes. Ensure that the change of calibration plate goes too. Again make sure everything is there , matches the tags and of course works. I'm not an expert however if you move everything over and all of the tags / paperwork matches and it smog's you should be fine. However double check with CARB .In fact triple check.
UPDATE!!! Keeping the computer with the motor worked great swapping into the new vehicle. The wiring worked fine, had to update the wiring harness on the trans and change out the sender for the transfer case along with it, but it worked perfectly. Also need to be sure to keep the same configuration on the exhaust as the motor computer was "used" to looking at. All good in the hood!
zems
12-12-2005 02:36 PM
casey_fordguy
07-21-2004 06:27 AM
