Over tightened the tie rod end?
#31
What is the part number of the tie rods you're using? At least then we'd know what was really wrong here. Just because the parts store says something is the right part, doesn't always mean it is the right part.
I'm fabricating some new tie rods for my truck using 1 ton GM TREs, a suggestion others mentioned. I'm going to be using "Y" Link Steering using GM 1 Ton TRE - RuffStuff Specialties that. Not quite applicable to a TTB though. Your method with the washers is a good temporary fix to move the truck in and out of the garage, but I would NOT drive that on the road.
The leaf springs on the TTB axle are supposed to have negative arch, so they'll sit either flat or in more of a ^ position.
#33
Nope, link geometry would be wrong but the taper is the same. Pretty much all full-size ford stuff from the 80-96 era is the same. The length of the taper in the D50 knuckle is a hair longer but that wouldn't affect fitment like we're seeing here.
#34
Oh man that sucks. I would rather it be the wrong part though instead of a knuckle issue.
the TRE that attaches to pitman arm is item number: ds1419
the TRE that attaches to the right knuckle is: es3363t
the left side TRE/drag link is: ds1420
the TRE that connects to the left knuckle is: es3362L
one adjusting sleeve is es2079s and the other is es2012s
Whats the verdict?
Whats the verdict?
#35
Just did a quick look on Rock Auto. They list ones for up to 4200lbs and ones for over 4200lbs for 2WD but all the same for 4WD so D44 and D50 makes no difference. I was wrong.
I have been thru this before and me and the parts store went round and round before I got the correct ones but I can't remember the details. I'm going to do some more research and post what I find.
#38
#39
OK. My last idea. 1995 thru 1997 shows the part numbers you posted. In a perfect world they should be correct, but for some reason they are not. However, 1994 and older show different part numbers. Someone in the trucks history may have replaced the front end with older parts because of a wreck or who knows what. I would go back to the store and get an outer right TRE for a 1994 f250 4WD and take it home and see if it fits. If it does, then you know what to do. If it doesn't, I am out of ideas.
#41
I think it's much more likely that the parts guy, or whoever boxed them when they left the factory screwed up and OP got tie rod ends for a totally different truck that just happen to be close enough to fit the adjuster.
#42
#43
I find it highly unlikely that Ford decided to machine some knuckles differently for the last two years of production.
#44
What book says this?
#45
Just my $0.02 USD worth
this is one of those situations where you take the old parts into the parts house, preferably one where you're known by the parts counter d00ds and drop the old parts on the counter. Only offer up a vague amount of info, like Ford truck of maybe this year, f-XXX under or over this GVW and tell them that's all you know for sure. use your best poker face while you do this.
A good parts man will know from experience how to deal with it. A few boxes later, you have what you need. With F250's, this seems to get the job done better than just going to the Discount Box Chain and hope the inexperienced d00d behind the counter has a clue.
I worked the line at the Ford Milpitas Plant so I observed running changes firsthand. things like '79 and '80 Mustang/Capri. Door release mechanisms are totally NOT interchangeable between the two years, even if the body looks the same. Even the trim bezel for the gauges took a change half-way through the year. The first ones fit great,just snapping in place then a different supplier's pieces took a mallet to get into the dash.
A scary thought; I may have helped build something you drove/are still driving. The early Fox body Mustang/Capri's, '80 - '82 Bullnoses.
