Computer compatibility
Well my truck has been messed up lately and y'all suggested that the computer was toast. After replacing a handful of parts ive come to the same conclusion. My only problem now is that I can't seem to find a remanufactured computer with the numbers i have on mine. Will any 1987 inline 6 with a four speed manual work or does it have to match exactly? I can't remember the number right off the top of my head, but I can get back with that.
I had another post with all I've already gone through with this truck. It has been absolutely nothing but problems since I got it but it was running. It wasn't running good but it was running. A couple of y'all on here indicated that it could be my computer and I began to agree with them because all of the sensors I replaced that should have fixed my symptoms ( ran fine until I stopped for any length of time then upon accelerating died almost immediately lime it ran out of gas. I replaced the tps and checked the injector pulse and idle air control) didn't. I also couldn't pull codes from it ( I realize it's an 87 and that they weren't wired for a check engine light but the way I checked it should have gotten something). So I went and got my new computer and installed it this evening (mind you the pumps were running before the new computer) . Installed it and turned the key and no buzz. Relay clicks but no pumps running like normal. Tried turning the key a couple more times... nothing. Ran back up to the parts store got my old one back and hooked it up trying to rule out that I got the wrong computer. Hooked it up and turned the key. Nothing. Took that back out and exchange it again. Now I have the new computer and my truck ain't even starting like before. Swapped relays nothing. I can hear them clicking though.
If you want to read about everything I already went through I'm sure there's a way to o find it somewhere.
Thanks for any help. I'm trying real hard not to put a match to it or lay a wrench across the terminals.
That's why you should have stuck to one thread....
For future reference: https://www.ford-trucks.com/forums/1...a-passion.html
