Which 4" lift kit did you use?
if it helps at all, the lift knuckle/diff drop kits are all mostly the same. in fact, the BDS and Zone options are identical - made in the same factory. the real differences are in the shocks and springs you fit into whichever you choose. I'm leaning strongly towards the Fox setup, since I have had good experience with their coilovers on my last truck. I'm also considering going with only a 2" lift. I like understated and functional more than mall crawler.
ReadyLift now has a 3.5" kit for the F150 that doesn't require the differential and all the related components to be mounted in a drop bracket. I would like to see some reviews on it.
I currently have a ReadyLift 2.25" strut spacer up front. Rides like stock and clears a 34" tire with no rubbing. I just want a little more clearance with the 157" wheelbase.
What are the other dimensions of that tire you fit with no rubbing (i.e. 275/65-R20, etc)? Did you keep the stock wheels? I'm trying to educate myself on all options before I order parts. Thanks!
One thing that sets us apart is out one piece reinforced sub frame. This adds a lot more strength than other designs, while maintaining proper CV and drive shaft angles.
Rancho 4.5" system, pretty sharp
2016 - 2015 Ford F150 4WD - 4.5-in. Suspension System - Ford - Suspension Systems - Rancho® Performance Products
What size wheel do you have? Feel free to call. We will help however we can. You will have a few variations of sizes all equaling the same height that you can use for the given diameter. Most popular set up is a 2" leveling kit on factory and a tire around 35 inches tall.
thanks for the info. great looking truck! I see you're one of the jerks that got the 6.5' bed. (I might be jealous)
I'll be doing the same thing via an add-a-leaf. I still haven't decided between a 4" lift and a 2" one... the price difference is pretty huge (especially if you include new wheels/tires), as well as the MPG hit. I think at 2" I would get pretty close to the same MPG running a 34" tire and I'd keep the stock wheels. I could even keep the stock goodyear tires for a while, which helps keep the budget under control. Just some Fox 2.0 coilovers plus the add-a-leaf could be about perfect for me.
Thank You for the input and education. With the lift cost, installation and havig to replace the stock 17" wheels I am now considering a 3" spacer, 295 0r 305 tires and an add a leaf in the rear. I'd like to stay out of divorce court also. I know the 3" is not recommended. Anyone else use that size spacer?
