1988 F250, set base timing 10*, now idles @ 30*
1988 F250 XLT Lariet, 460, C6, 4x4, reg cab, long bed
I promise everyone, I searched this topic. I didn't see the answers I was looking for.
I've set the base timing to 10* BTDC with the spout out. Then, with the spout in and using my timing light, at idle, it shows 30* BTDC. It idles at 750 rpm and it seems a little rough, no misfire or anything, but the whole truck seems to vibrate. Also, the exhaust smells really rich.
I've checked for fault codes KOEO, only "11". I have not take it on the road yet.
So, my question is this: using my timing light how much timing advance should I be seeing while at idle, spout in, on a 1988 460?
It will throw a ton of timing at idle with the spout in. No load on the motor, no problem. The computer does what it needs. I bet if you have someone put it in gear(holding the brake) it would drop the timing some.
My '89 302 had the same kinda "shaky" idle. Not dead smooth like you would think it should have with a stock truck motor.
Rod Beauvex
05-05-2014 02:39 PM
bb429power
12-09-2012 11:29 PM
MattP51
06-29-2011 09:03 PM
northlandman
12-01-2003 06:49 AM
