1994.5 f350 7.3
#31
#32
No the only thing I replace was the pigtails for the valve cover gasket replaced the whole fuel bowl harness I replace the high-pressure oil pump I replace the IDM replace the ejection pressure regulator I replace injection pressure sensor but my wait to start light does not come on I did fall your chart only thing that does not work is the glow plug relay but I do not need the glow plugs because I live in Southwest Florida where it's always hot
#35
Check your fuse #22 under the hood. Check all your fuses in the fusebox under the hood. It sounds a little like you shotgunned the repairs. Start from square one and remember that slow is smooth and smooth is fast. I'd seriously start from the top, check every repair you have done like connections, wiring, etc, and just go down the chart step by step. You must be overlooking something. And the biggest thing...DO NOT get in a hurry! LOL....take your time. I have overlooked some very rookie stuff by going too fast.
#36
I have already replaced all the fuse and I just double checked them and they're still good the last time I got my truck started was two months ago when I put my chip in then it wouldn't start so I took the chip back out and I blew a high-pressure oil linefix that and put all the new parts on it still won't start
#38
Keep in mind that the WTS light is the signal we all look for to see if there is power to the PCM. If the WTS light bulb was burned out before and the truck ran then there was power going to the PCM. Now if there isn't power going to the PCM (or the WTS light), because of another problem then you will have to test for power at the PCM or else you are wasting time fixing things that may not be broke.
How much fuel is in the tank?
Kevin
#39
#40
Did you unhook the battery before taking the chip out?
I am going to get in trouble for this one, but I think the '96 PCM should start your truck.
Kevin
Kevin
#43
First I would get a test light or a volt meter and open the fuse box under the hood. Check for battery voltage on both sides of the top of fuse #22 with the fuse still in the box with KOEO (key on engine off). Should be a 20 AMP according to the online manual. (oops on my truck it is 30 AMP).
Then pull the diode #12 under the hood, one pin should have battery voltage, the other one not.
If that checks good, then turn the key off pull relay #1. See pic below.
On my truck, under relay #1 there is 12.xx volts on the pins at the 2 yellow arrows, and 5.xx volts on the pin at blue arrow. There was 0 volts on the other pin
Turn the key back on and check for voltage on the pins under the relay.
If that checks ok, you might be able to swap relay #1 and relay #3 (horn relay) and see if that makes a difference.
I haven't found which pin(s) feed the PCM connector with 12 volts yet.
Kevin
Kevin
