2017+ Super Duty The 2017+ Ford F250, F350, F450 and F550 Super Duty Pickup and Chassis Cab
Stickergate / Rear GAWR on SRW 350 is only 6340#???
Old 08-26-2016, 12:18 PM
System's Avatar
System
System is offline
Prolocutor
Received 1,198 Likes on 573 Posts
Really? Do I have to start planning all over again. Please tell me this is a bad dream?
Old 08-26-2016, 12:23 PM
Highjumper's Avatar
Highjumper
Highjumper is offline
I just spotted that also. Just a guess, but I am wondering if it is due to the snow plow package on that truck, which seems to have increased the front GAWR from 5,600lbs to 5,990lbs. Anyone have an earlier MY truck with a snow plow package that can weigh in on how it affect their GAWRs?
Old 08-26-2016, 12:25 PM
System's Avatar
System
System is offline
Prolocutor
I have plow prep. It has no effect on RAWR.
Old 08-26-2016, 12:35 PM
johndeerefarmer's Avatar
johndeerefarmer
johndeerefarmer is offline
Did he post payload on that truck?
Old 08-26-2016, 12:37 PM
System's Avatar
System
System is offline
Prolocutor
Not that I saw, but it won't matter much with that GAWR. How can you have a GCWR of 28700# and a GAWR of 6340#? It makes the GCWR completely useless....
Old 08-26-2016, 12:40 PM
johndeerefarmer
I think Ford must use that "new math". These numbers make no sense.
Old 08-26-2016, 12:44 PM
System's Avatar
System
System is offline
Prolocutor
Wait til 2009KR sees this fiasco.
Old 08-26-2016, 12:58 PM
EpicCowlick's Avatar
EpicCowlick
EpicCowlick is offline
Rear axle may be limited by something other than the actual axle itself. Namely springs. Adding airbags can increase the numbers quite a bit.
Garyl53's Avatar
Garyl53
Garyl53 is offline
My '11 F250 Drive Axle with only the hitch in the bed is about 3300. Don't know what a '17 F350 would be but that would only leave about 3000 lbs max. or maybe a 15k lb 5vr with 20% pin weight. Sure appears low. I would have expected at least 6750 to 7000 rating.
Old 08-26-2016, 12:59 PM
System's Avatar
System
System is offline
Prolocutor
Nah, all the 11-16 SRW 350s were 7k rated. And, there is no spring option you can change on a SRW 350. My 5th has a very light pin for what it is but I'd still be over if this rating is correct. It just makes no sense that everything was strengthened and yet the axle rating went down 660#? I'm wondering if that sticker is a misprint.
Old 08-26-2016, 01:09 PM
EpicCowlick
Wasn't there something that showed the rear axle even higher? Like 7,250 or something? I'm with you about the rating going down and it doesn't make sense. I need to find that. The numbers we are seeing are all over the place.
Old 08-26-2016, 01:11 PM
System's Avatar
System
System is offline
Prolocutor
Right??? That sticker has to be a misprint. I tried doing a chat on the build and price and after trying to tell me the GCWR I was told that they didn't have that info and to check with my dealer service manager... Very helpful...
Old 08-26-2016, 01:15 PM
troverman's Avatar
troverman
troverman is offline
Old 08-26-2016, 01:21 PM
System's Avatar
System
System is offline
Prolocutor
Just found the similar here on page 24 but slightly less at 7230#. That's with 20's. With 18's it's 6780# and with 17's it's 6340#. I'm thinking that sticker is a misprint as if the truck came with 17" wheels.
https://www.fleet.ford.com/truckbbas...ecs_8-5-16.pdf
Old 08-26-2016, 01:26 PM
EpicCowlick
Glad you guys found that so quickly. I was kind of sick for a while. Now everyone has to check their stickers and make sure they are correct. I mean, wow. I'm willing to give Ford a break but this kind of stuff is just embarrassing.
Quick Reply: Stickergate / Rear GAWR on SRW 350 is only 6340#???
