Hellwig pro series helper springs 61904
I feel you, but if I had to do it all over again...new leafs are the way to go. Band aids are just that band aids...I added the RAS before I did the spring swap, and while it did help quite a bit, I wanted more, so I swapped the rear springs and that took care of most of my problems. I just put the RAS back on so it wouldn't be sitting in the garage..lol!
What is your location? ATS Springs in PA is a site vendor and has a quality product with tons of reviews here on the forums.
fair to say you want to cure the wander and not sway ?
get me those corner measurements and We can get into the fix,
while you are getting the measurements also inspect your front bump stops. ( a pic of each one would be helpful )
in the rear inspect the frame mounted bump stop and the rubber snubber that is on the very bottom leaf. ( again a pic of each would be helpful )
Ill be happy to walk you through it if needed.
https://www.ford-trucks.com/forums/1...l#post16086297
please read and understand this before you get an alignment.
#28
Both rear= 24"
#30
2. no need to play with air pressure the "correct" pressure is based on tire size and vehicle weight. the factory 265/75/16 pressure is 50 and 55
look at your door sticker for your axle GAWR for front and rear. divide each by 2 and then find the weight and pressure on the chart below.
My 7.3 Ex is front GVWR 4700 and 5200 so each front tire needs to support a maximum weight of 2350 and 2600 lbs. looking at the chart for a 275/70/16 i see the fronts should be 55 and the rears 60
