1972? F250 4x4 electrical issues
Hi Guys,
My title and door tag says I have a 1972 2wd f250. The transfer case / front driveline / front axle would disagree with that. I think this was a 1972 2wd cab / bed put on a 4x4 chassis.
Here is my question. I have a dash mounted emergency flasher switch and one on the column. My turn signals do not work. Dash switch works with key on or off, column switch only with key on. I suspect the column is from a diff year truck than the body. I'm planning to replace the turn signal switch setup as the switch does absolutely nothing. I tested with a meter, no changes when the switch is put in any position.
I also have only one flasher unit under the dash, and do not see a location for a second one.
Ideas?
Thanks,
Ryan Minihan
Ideas?
Thanks,
Ryan Minihan
on
That column is from a 73-79. To check the frame vin, look at the top of the frame rail under the passenger door. It should start with F26 for 4wd. Are the front leaf spring hangers connected to a front crossmember? If so, that could signify a 67-77 frame. Without a front crossmember signifies a 77.5-79 frame. Does the cab and bed have a large gap? That signifies a 73-79 frame due to a 2" increase in wheelbase. Is the transfer case divorced or married?
