Truck Delivered
#62
#63
#64
So, back to the manual transfer case shifter and traditional hub set up. What's everyone's take on leaving the hubs locked for periods of time. Such as 30 miles drives, highway speeds and so on?
The old opinion was always that it could cause undo wear on the front pinion / diff, and of course cause decreased fuel mileage but the fuel issue does not bother me.
If you think about it years ago very few trucks had lockable hubs. No one wanted them because it was felt they would fail when you needed them the most. Some did which were never taken care of. Now many people feel the same way about shift on the fly technology but their numbers are decreasing.
#65
The picture is deceiving, it flattens out towards the front of the hood and will not hold water.
#66
Manual or otherwise the front hubs should be turned in a run at least 10 miles every month. The grease in the front axle U Joints needs to be stirred up. If the axle shafts are static for too long a period unusual wear starts to set in and the seals also start to harden from only single direction movement, every time you turn the steering wheel. In day of old you would notice this if you didn't turn the hubs in all summer and then the first time in the fall or winter the u-joints would yank the steering wheel until the grease got circulated over the dried out spots. So everybody, turn in your hubs and let them warm up monthly.
I've always been under the impression that the front side was not set up to the same tolerances as the rear.
#67
#69
#70
Thanks for posting regarding the RPMs at speed. I ordered an F-350 dually as well, and it is 4.10's. I was on the fence on that one.
Nice truck. The Michelin's *are* AT tires, just not good ones. I wanted the black side wall like yours, but the dealer ordered the white letters.
Can you verify if the dually fender lamps and clearance lamps under the tailgate are LED?
Thanks
Thanks
#71
Nah, Manual T-case are tried and true. Google "failed ESOF" to make you feel better. Some demand the manual t-case to have an extra low range in 2wd for towing equipment in certain circumstances.
#72
Yes you can tow in low range and not lock in the hubs but the flip side is the tremendous torque which low range puts on the drive line. It would be better to have the front wheels pulling as well if you need that deep of a reduction to tow.
#73
Easy enough to add a switch to break the circuit for the vacuum solenoid. I occasionally use 2 wheel low to back up into my driveway (with 19K of toy hauler)
#74
Will be interesting to see, especially if parking on a hilly driveway.
#75
Thanks, appreciate it.
No need to worry at all about the front diff. Its a Dana 60, used as a rear diff in plenty of vehicles (and therefore turning at all times). Its a massive diff and you can't kill it. You could disconnect the rear driveshaft of your dually, put it in 4Hi, and drive around for years in front wheel drive with no issues.
