I doesn't have a yellow. I have the SCT analog cable and it has 6wire. And a diagram. The edge EGT has 5 wire. Red black green red and just regular silver wire.
So as far as I can get is. Wire the red and green wires together from the edge EGT and sct analog then power and ground. It reads but it isn't reading correct temp. Just hangs around 190ish
