06 f250 fog lights not working. need help??
Hi! New member here I have a problem with my F250 2006 6.0L. I cant seem to get my both fog lights to work. i checked both bulbs are good. I checked fuse 43 an its good. When I turning fog lights on I see a small light that turning on in the panel but the fog lights outside are off. I hear the sound of the relay when activate the switch but I DONT have 12volts + in the fog lights outside?
They worked several days ago but not today
help please
help please
Fog light help
I know this post is 7 years old but I just came across it and am having some similar issues. I found one side of the grey plug for the harness. But when I pulled the harness to where I could see it. It wasn’t plugged in to anything. It was jammed up under my steering gear box. And I can’t seem to find the other end to plug it back in.
The helpers
help please
help please
I did tried it and wow it works again with all led lights on it including the fog lights
I hope this helps you
diehardstroker
11-18-2013 11:15 PM
