How limited am I with speed density!?
on
Your plans are outside what the factor SD PCM can adapt to, it is preprogramed for a 302 motor with fairly modest airflow characteristics. The good news is if stroke it out to a 347 you may be able to utilize an SD 351 PCM as long as you don't go too radical with the cam or bolt aftermarket heads on it.
The SD system is programmed to be 10-15% rich at WOT (or so I read long ago) so don't increase the airflow more than that amount. And don't do it that far until you've cleaned the injectors first to make sure they're flowing what they're supposed to. K&N + Cobra roller rockers (1.7 ratio) and possibly the F4TE roller cam is about all you'd want to do before getting into trouble.
mroseboom10
05-21-2015 02:05 AM
TheTowingCowboy
02-23-2013 11:56 AM
first today
06-10-2010 05:02 PM
dmc919
01-02-2007 04:59 AM
