AE question, and missing truck
My kid started my new to me 97 friday. He was going to start moving some of my stuff to my shop (where I'm moving to). I'm a little banged up with a bad foot. It was missing bad, cel on. Ran good the other day when I used it. Parked it and used the ranger. Anyhow, today I pulled the codes. 0113, 0603, and 0344. Not thinking the cam sensor would do this I changed it anyway. No better. Now the codes were 0113 and 0470. I pulled both the passengers side plugs to the vc's and it ran the same. I'm guessing I need a wiring harness, and will pull that valve cover in time, but I'm curious to as what set the cel, the 2nd time for sure, but both really. Any thoughts? Did it just come on for the rough running truck and didn't set a code?
I first tried to use AE to pull the codes. For some reason I can't get it to pull codes. Not the first time I've tried with no success. I connected to the truck, etc., and when it asked to pull codes I clicked on "All" once and "current" once, both times said no codes were present. What am I doing wrong? I went and got my scangauge from the other truck and pulled the codes mentioned above.
A short in an injector can shut down the bank to protect the IDM.
Time to OHM things from IDM connector to UVCH
I've ohmed the injectors through the vc's before and number 1 was 4.0 where the others were where they are supposed to be, 3.2 ish. I know they are weak, the truck has 374k and as far as I know they are original. Number 1 doesn't fire when cold. This time of year it has been, but last winter it wouldn't until it was warmed up a bit. Once I get all moved I'll bring it in the shop for more testing.
Certainly no fun with a sick dd
But more than all that I hope your foot isn't anything serious.
Get well soon!
I got the truck in the shop finally. I tested the injectors through the harness and was getting an intermittent reading on both 1 and 3. I only tested the passengers side since it was the bank that shut down. Then for the heck of it I plugged in my spare idm. It ran just fine, until it realized there was a problem and shut down the same bank. So I pulled the valve cover. The outer harnesses looked fine. The inner was a totally different story. The front plug was almost welded together. I broke the heck out of it pulling it apart. There was nothing left of the gp's, and the injector connections aren't far behind. So off to riffraff to order parts. It looks to me like they are all original. At 374k I say they lived a good life.
