My new truck V2
Old 10-19-2016, 05:23 PM
FI460's Avatar
FI460
FI460 is offline
Originally Posted by mcali2
If you were going to change the trans , what kind would you go to? Don't they have 6 speeds now?
It's not worth it to go to a newer auto. Trying to get the PCM and TCM to talk would be a nightmare I imagine.
IMO a zf-5 swap is the way to go but if you want an auto John Woods builds a good E40D, right Glenn?
  #212
Old 10-19-2016, 05:37 PM
oldbird1965's Avatar
oldbird1965
oldbird1965 is offline
Right.....
  #213
Old 10-20-2016, 06:48 AM
El Camino Man's Avatar
El Camino Man
El Camino Man is offline
Originally Posted by cowmilker08
From what Mark K says the 5R110 is a nightmare for tuners compared to the E4OD/4R100.
i could see why. The E4 and 4R are both relatively simple, especially ehen compared to the 5R110. The 5R has soooo much more electronics involved
  #214
Old 10-20-2016, 07:31 AM
DIYMechanic's Avatar
DIYMechanic
DIYMechanic is offline
Originally Posted by El Camino Man
6.0s have the 5R110. They're beasts lol
Yeah, I don't know why I typed 100 instead of 110. Must have been thinking of the 4R100 in the earlier SD trucks. 5R110 is what I meant. I'll go back and correct my error.
From what I have heard the 5R110 isn't as easily tuned as the 4R100, and some drag racers prefer the 4R to the 5R for the quicker shifting capabilities. It sure seems like a good truck transmission though.
Edit: There, all better!
  #215
Old 10-20-2016, 12:32 PM
cowmilker08's Avatar
cowmilker08
cowmilker08 is offline
I would just get a built E4OD if I were to do it. John Woods isn't the only option out there.
  #216
Old 10-20-2016, 06:05 PM
mcali2's Avatar
mcali2
mcali2 is offline
FML. POS FORD BROKE AGAIN. FUEL SELECTOR VALVE BURNED UP 500 MILES AWAY FROM HOME. STUCK ON THE SMALL TANK AND GAUGES NOT WORKING. FORD WANT 500.00 cheap no name is 75.00 but you use hose clamps and have to re wire it. I've had 2 of them in the past on a dunebuggy and they did not last 1 month. Is there a better option? I want duel tanks but may have to hardline the large one and add a pump to transfer the small tank to the large tank.
  #217
Old 10-20-2016, 07:27 PM
Jarrett Campbell's Avatar
Jarrett Campbell
Jarrett Campbell is offline
Dude I feel for you...
but would the selector valve cause the gauges to not work? You could go off of mileage to get home at least... that's what I did getting from ND to TX when I got laid off.
  #218
Old 10-20-2016, 07:42 PM
dclack's Avatar
dclack
dclack is offline
I've had one of the parts store ones on my Bronco for a few years now without issue. Just don't get one from a junk yard. The seals dry out quickly when not in use. You could get a used one from someone parting out a truck that hasn't been sitting too long.
  #219
Old 10-20-2016, 08:07 PM
mcali2's Avatar
mcali2
mcali2 is offline
This one was a used on. Worked great when i put it in. I used it 1 time and was good flipped tanks and worked. Went to flip back and the fuel gauge went way too far. I knew it was busted then. Lucky for me i was in a town to fill the small tank. I did not know what tank was feeding the engine. I was afraid it was stuck between the front and rear tank. Like the gauges. I ordered a new ford part on amazon for 305. I hope they have improved the design. Do you have to use them all the time to keep them working? Seems like it just jams or shorts out and burns up. That thing gets really hot. I unpluged it but that made the battery light flicker on and off.
  #220
Old 10-20-2016, 08:15 PM
dclack's Avatar
dclack
dclack is offline
I do use mine regularly. I have pulled 3 from junk yards to use on my Bronco and all of them leaked from the start.
  #221
Old 10-21-2016, 06:20 AM
DIYMechanic
Yes, the selector valve switches both the feed lines and the gauge wiring to the tanks at the same time, so when it malfunctions you can lose the gauge function as well.
Man, that sucks. I had mine fail on me (mostly due to my own stubbornness) and I replaced it with a used one that has worked flawlessly (so far- knock on wood). $300 for that thing is ridiculous. Hopefully that one lasts as long as the original did for you.
  #222
Old 10-21-2016, 07:44 AM
Bob_T's Avatar
Bob_T
Bob_T is offline
Dumb question. What about replacing the selector valve with a tee and using fuel from both tanks at the same time? Wouldn't matter which fuel level sender is active since both tanks will be at the same level. Only problem I see is when they get real low one tank might start sucking air while the other may still have a bit of fuel left.
  #223
Old 10-21-2016, 08:51 AM
nateairman's Avatar
nateairman
nateairman is offline
I believe a few of us have put a 38 gal rear tank in so it would definitely be sucking air.
  #224
Old 10-21-2016, 09:17 AM
Bob_T's Avatar
Bob_T
Bob_T is offline
Yeah, you'd have to install some sort of balance tube between tanks to keep the levels equalized.
  #225
Old 10-21-2016, 09:18 AM
farmert's Avatar
farmert
farmert is offline
If fuse #6 in the in cab fuse panel blows, it will make the gauge read funky also. This fuse also is for the AC clutch.
Quick Reply: My new truck V2
