Ford 6.8l v10 knocking
Hey all, new member here. I have a 6.8l V10 that ..... seems.... to be knocking. I am used to hearing v8 knocks but not so sure about a v10. The knock seems to double tap sometimes. Could this be a bad valve or lifter instead? Video is linked.
Also oil pressure seems to be fine.
youtu.be/P5rK7L2hYys
Thanks
Martin
Thanks
Martin
That's a hard call the used motor seems overpriced but I would prefer a low mile factory motor over a rebuild like jasper. I look at the factory motor as having been built better to factory specs with all oem equipment and with miles on it, if tested/documented before it was removed, I see it as proven. But I would be doing the install myself. So I'm guessing with the jasper motor and a shop install you have warranty for a certain period of time for whatever that may be worth?
Cat delete, and new borla exhaust. ( we were having fun) no, it didn't sound like that before. And it drove for sometime after the new exhaust install without a hitch.
As far as the new motor. The jasper would come with a 100,000 3 Year warranty. The used comes with a 6 month, 12,000 mile warranty. If i had my own shop i would install it myself but i don't even think my motor picker could even lift the motor.
I don't know, I can get a Ford reman here with a 3yr/unlimited mileage warranty for $4500ish. Have you tried a few dealers or wholesale places that deal with Ford. I would definitely want new.
156,000. That's with synthetic oil it's whole life with motorcraft filters. It happened after i replaced all 10 coils and plugs and put a new exhaust on it. I didn't know if that might have something to do with it. Here is a video of me driving it. Still sound like a low end knock? https://youtu.be/yD0ir6yIe3U
That sucks.
