Engine Swap in 81 F150
Doc was a Hudson Hornet.
1952/54 Hudson Hornet's with the 308 cid flathead 6 and dual carbs dominated NASCAR .. soon became known as the Fabulous Hudson Hornet.
Jack Clifford, well known for hi performance 6 cylinder parts got his start offering speed equipment for these engines.
Jack Clifford' Performance Products inc. - Headers Intakes Cams For Inline Six Cylinder Engines, Inl
This is perfect. I had heard some bad things about the 351M and the 400 but as Gary said neither of those will bolt on to what I have already.
Is it worth just considering a new intake set up and exhaust manifold on the 300 that I have? I mean the truck isn't used for much as far as hauling, I just wanted a slightly better response from it.
If you want a engine with more zing to it, you need something that revs faster and gains rpm quicker with a shorter stroke. Don't go to short and small though, after all this is heavy pickup, basically a metal box on wheels. I agree the 351w would be the best choice for a swap.
With the long stroke, the 300 will always seem "lazy" and slow to rev. This engine shines with a load in the bed or behind on a trailer. I don't think carburation or a manifold is going to help much.
The 6-banger forum here on FTE can be helpful, too:
Ford Inline Six, 200, 250, 4.9L / 300 - Ford Truck Enthusiasts Forums
80ford100
71
01-23-2015 08:24 PM
dusterfanatic
10-01-2012 12:00 PM
