Air filter system on Banks Sidewinder turbo.
Last night I finished up assembling my 6.9, it's pretty much ready to go back in the truck. I decided it would be a good idea to do a quick test fit of all the components of the turbo kit. I bought it used, so I wanted to make sure I have everything I need to make it work. I noticed the air filter element is a washable oiled cotton and gauze type construction; much like a K&N. I've heard it's not recommended to run this type of filter on these engines. Is this true, what do you guys recommend?
That's what confuses me, I've run K&N products on nearly every gasser I've ever had with no issues. I am a stickler about maintenance on my rigs. The oil is intended to catch the smaller particles, that's a good thing right? A washable/reusable air filter always seemed like a nobrainer to me.
Fine particles will go through a gasser just fine but when you try to run then through a turbo wheel spinning 100k RPM you will sand blast that wheel in a hurry. Plus the 400 PSI cylinder pressures of a diesel force all those fine particles into your rings, and wear them out faster then a lower pressure gas motor.
FWIW, ag diesels with a turbo have used 2 air filters since the 60s, 1 inside the other, the internal is just a backup/ safety if the main outer fails.
Air filtration is utterly important for longevity of a turbo diesel.
Received 3,108 Likes
on
the day after getting the banks turbo put on my truck i took the airbox off and when done it looked like this:
for the next 5 trucks the air box was cut to be like this one before they were ever put on.
i had used a bunch of different air filters over the years on the trucks, but eventually settled on the 6637.
on
That was going to be my next question, what you did for the CDR. I am going to run into some clearance issues with set up I have now. Apparently the bullnose trucks have a slightly different firewall setup. Banks instructions say I need an adapter to clear the CDR. I got my turbo kit used, it's missing a few items that being one of them. Would I have to use aluminum tubing for the intake, could I use steel? Would you mind posting a couple more pictures of your intake setup? Thanks again!
on
what truck are you putting it in?
this was the temporary setup i used to bring it home from the machine shop where we cut up the airbox. yea, i know the cone filter. but it was only on the truck for 6 miles.
you can see the CDR mount mid tube on the intake
the CDR should be no where near the firewall, it mounts to the driver side of the airbox.
the reference to the firewall is the upper seam/floor pan seam that needs to be flattened to give clearance for the turbo and down pipe to fit.
on
I do have that spacer/adapter and the hose. The adapter I'm referring to per the Banks instruction manual actually bolts to the intake elbow, then the CDR bolts to the adapter. Another snag I ran into is the transmission dipstick tube, it looks like they have a special one that would come in the kit. I'm pretty crafty with fabbing things up, I'm sure with some massaging I can make the original one work. Unfortunately my aluminum welding skills are pretty much zero, so building the intake tube might be a bit of a challenge. Fortunately I know people, so that shouldn't be too big of an issue.
on
