6.8l v10 crankshaft trigger wheel?
Long story extremely short
3 months ago bought a 2002 E350 Superduty van with 6.8l V10 and 170k miles for $1000 that had a miss,loss of power and hoped it was just plugs/coils or catalytic converter.
Ended up throwing parts at it......
New plugs,coils,IAC,PCV,fuel filter,02's,cam sensor,alternator.....
catalytic converter checked good, fuel pressure good, keep getting p0340 cam sensor fault code.
Tear the front end down to check timming components.
The crankshaft balancer bolt is missing and from the amount of grime in the threaded hole its been missing for quite some time.
Get the front cover off and chains tight,guides and tensioners good but notice the trigger wheel has about 20 degrees of play where I can spin it on the crank left and right and it also has what looks like damage.
Does the crankshaft bolt pin the trigger wheel in place and without it mine was damaged?
Could this be cause of rough idle, hard starts, lack of power when FOT? otherwise drives ok.
I cannot find a replacement trigger wheel. Mine has 39 teeth and theres one on ebay that says its interchangeable but it has 35 teeth.
Cant find a replacement anywhere I look online.
They all state they fit the 4.6 or 5.4 but noone that states for 6.8l
Any help would be greatly appreciated!
LOL - looking for the part number on your trigger wheel, I found your other thread on this subject.
https://www.ford-trucks.com/forums/1...desperate.html
There is a Standard Motor part, PC615 that covers 1997-2002, and then nothing.
I checked ford-parts.com, and found that they don't list much for anything before 2004, but for 2004, they do list it, at $17.45 - you say that van is a 2002, but ... is it possible the engine was swapped? Because that tone ring you have should be the older style, with the F7 part number. Not that XC one.
[img]http://www.fordparts.com/Commerce/RenderIllustration.ashx?id=356966294&f=3&n=XC3Z12A 227AA[img]
Ah, I see the difference in the "reluctor wheel" is thick or thin (stamped metal).
From an article for the 4.6L but I'm assuming it was the same for the 6.8L: Rebuilding The Ford 4.6L - Engine Builder Magazine
Crank Gears and Reluctor Wheels
Be sure to use the matching crank gear and reluctor wheel. The engine won’t start and run if you are using the thin crank gear along with the thin reluctor wheel. Installing the thick crank gear with a thick reluctor will crack the front cover when you bolt it on and lock up the engine, too.
So you could use a Standard Motor part (thick) and a thin crank sprocket.
Krewat....thanks for your diligent research!
For whatever reason the crank bolt has been missing off the crank for some time by judging by the grime on it. Theres a ford dealer "this modification has been made" sticker on the rad clip but its weathered so no idea what they did.
I havent been able to find the trigger wheel new online anywhere that looks like mine with 39 teeth and 2 holes opposite the key except for a used one on ebay. Unfortunatelly im broke untill fri so I hope its still there.
Also.....sorry about having 2 topics going...the other one is more for my whole timing component procedure and less viewers in the van subsection. I think part of my problem is not a large amount of people have worked on the 2v 6.8
More than likely - the dampener was probably slamming it. Or, the wheel broke, causing a loss of torque on the dampener bolt and that's why it left, but I doubt it
I suspect, however, someone had the motor apart, didn't lock-tite the bolt and it came back out. Or the motor isn't original and they had to change the dampener to match the accessories. Weird stuff.
Like I said, supposedly, the change in the wheel was for 2003, according to Rock Auto info, but I can't be sure of that either. I think your motor was changed.
And to be sure, I have ran VINs of a couple 2002 E-Series vans with V10s in them just to be sure. If the OP doesn't mind posting the VIN of his van so I can run in HvBom and even Microcat at my workplace just to be sure, I don't mind doing that either.
That's because that is NOT the part number. That is what Ford calls the ENGINEERING number, or STAMPING number, not the actual part number. For it to be an actual Ford part number, that last letter of the four digit prefix has to be a 'Z' (or 'Y' for older Lincoln/Mercury model specific parts).
