1968 f250 power steering gearbox
#46
#48
Quick update - after the gearbox was bolted back in place, I got to work on the bushings, tie rod/drag link and other fun stuff.
The I-beam bushings were quite a bear. The ones I ordered 6 months ago were from LMC and i decided to use them. It took a bit of filing in the right places to get them in there plus some work with a Little hammer. Looking back, I should have left the original metal shells in there and ordered some poly bushings but lesson learned
The tie rod/drag link were Moog, and great quality. Prothane radius arm bushings were also nice.
I matched the new tie rod (same length, shape, direction etc) to the old one and everything went back together great. Assume I'll need to get it aligned.
Dropped the truck on the ground and cranked it up. Everything looked and worked great. I'm just happy the rebuilt Bendix box isn't leaking! Can't wait to get this think back on the road.
#49
#50
#51
#52
#54
#55
#56
Sorry to hear this. Check for leak at the pump and hoses. Maybe the pump is leaking and it's trailing to the gear box. Or maybe the flare on one of the hoses is split so it's not sealed at the box.
#58
on
Back in the day this was the normal thing we had to do to CYA
if not you had to remove the part an tighten all the screws/bolts/nuts.
Right Jeff!
Orich
#59
Yepper. Parts back in the day were built better. By AMERICAN workers. But ya still had to double check bolts and tightness. Didn't have to tighten more often, but better safe than sorry.
#60
Front right disc is locked up now. Still rolls but you can't turn the tire by hand. I may have stretched the brake line when I was changing bushings but not sure. Guess I'll start by replacing those and go from there.
On on another note. What kind of replacement calipers could I use and where to buy them? Everything I seem to find online is the whole disc brake kit
