71 f-250 4x4
#34
I guess I'll try Napa again. Last week they told me they couldn't cross reference the part number that ND gave me. I guess I'll have them look it up by vehicle instead of part number.
#36
#38
Mason, that appears to be one really nice truck you have there. I'm restoring a 71 f250 4x4 myself. My transfer case is also the NP205. Contrary to what some other members say, mine came stock (as apparently did may others). I'm not sure it was an upgrade, different option, or what, but I've never seen a 71 f250 4x4 with the Dana 24, they all seem to have the NP205. AFAIK the 205 is one of the best transfer cases. I rebuilt mine with a total rebuild kit (widely available).
More to your original point, I am looking for a replacement speedo cable myself. There is a guy on Fleabay who sells hundreds of them, and I am working with him to see if he can get me the correct replacement. He's away till next week but if he gets me the correct part I will let you know.
If in the meantime you find the correct replacement someplace, I'd appreciate it if you would let me know. Thanks!
#40
on
Mine came with a dana 24 and have not come across any others in 20yrs of Junk Yd scrounging. I've only found them in the later 73 & up.
The easiest way to spot one is the lD tag faces to the rear of the vehicle. Where as the D24 ID tag is on the side of the case. Plus different speedometer cable end at the TC.
The 205 is the push in type & the 24's has a screw on collar.
The 73 & up truck speedometer cables are have two different cable ends making it not unusable on a 72 & down trucks yrs.
Other vehicles use the same 205 speedometer cable TC push in type on GM's and the 2wd fords auto trans don't know all of the yrs that shared this cable end. Just have one made up that is long enough or buy the cable adapter end for the 205 TC
Orich
Orich
#41
#42
on
#43
#44
I've found the correct cable on Fleabay, if you search "103 inch speedometer cable" it's the first one that comes up. According to the seller who seems to have a good rating, it's the right one (although listed for an Econoline, for God-knows-what reason).
$58.95 seems a little steep after the prices other guys were talking - the adapter is still only 12 bucks on summit. Where are you getting your cable, and what price do they want?
