I'm going to do a manual swap, few last questions.
I pulled the engine and tranny yesterday, not too difficult, about the same as any 7.3.
After I got it out it doesn't look like the pan is bad, I think it might be the one valve cover.
I am doing pretty well with selling part so far, when it's all said an done... I may end up making money wit the swap.
Today, I have finally started tearing it down. It took a while for the new tranny I bought to get here, but finally made it.
A gentleman I spoke with said early 99 had the barometric pressure sensor behind the dash, and after that they were in the PCM. The PCM I have from the parts truck is late 99, does anybody know if I can jus unhook/ splice a couple wires, or do I have to swap the entire cab harness?
Fix ZF Manual Transmission Ford PowerStroke & GM Duramax Shifter Problem
A new OEM replacement stub is about $100, the short throw is $215 (- the 10% first time buyer discount they offer, so really its about $195).
If your trans is not coming with a shift tower, then you will also need a few extra parts, namely the shift tower housing. I believe Midwest has that too, for about $40. I suppose you could rob that from the 2wd donor truck, but then that trans becomes harder to sell. Just get a new one, as they can also wear where the bushings sit.
You will also need the 2-piece boot bezel ( the inner white boot does a lot to reduce noise in the cab - the bezel screws go through 4 corner holes of the white boot - it does not just sit in there), as well as the shifter stalk itself.
I have no idea what they can flash onto it. I just remember that code from when I got a chip for mine like fifteen years ago.
#28
#29
#30
I haven't really been making any progress, engine is all back in and cleaned up, plus the pedals and column are swapped. The problem I am having is the clutch release fork. I ordered one from summit, but it's not the correct one. I went to autozone, an they have the same small one listed. I went to Napa, they do not stock it and can not get it. I just called a couple dealers and they also don't stick it, but they can get it for Teusday. Does anybody have a part number for it, or know for sure a website with the correct one? Having my truck down is really becoming a hassle.
